查看: 26853|回复: 1
Atmel Power Deugger Kit ---ATMEL新仿真器横空出世!
发表于 2015-12-17 20:12:35 | 显示全部楼层 |阅读模式
号外:Atmel Power Deugger Kit ---ATMEL新仿真器横空出世!
Key Features关键特性:
  • Supports JTAG, SWD, PDI, TPI, aWire, SPI and debugWIRE interfaces
  • 支持JTAG, SWD, PDI, TPI, aWire, SPI and debugWIRE接口
  • Two independent measurement channels measuring both voltage and current simultaneously — One high resolution channel that can measure 100nA to 100mA and one lower resolution channel that can measure 1mA to 1A.
  • 两个独立的测量通道:可实时测量 电压和电流--一个可测量100nA到100mA的高分辨率通道和一个可测量1mA~1A低分辨率通道
  • Adjustable power supply that can be used to power the target application — Voltage adjustable between 1.6V and 5.5V. Can deliver up to 100mA
  • (可向目标板供电的可调电源)
  • USB feed-through connection for easy measurement of current consumption of USB powered target board
  • USB直通口--方便测量USB供电的目标板实时功耗
  • 1.62 to 5.5V target operation  目标操作电压范围 1.62~5.5V
  • USB powered
  • Provides both ARM Cortex Debug Connector (10-pin) pin-out and AVR JTAG connector pin-out
  • 提供 ARM Cortex Debug Connector 和AVR JTAG调试接口
  • CDC virtual COM port interface
  • Atmel Data Gateway Interface channels for streaming application data to the host computer from a SPI, USART, TWI or GPIO source
  • ATMEL数据网关接口通道--以便主机分析目标板数据
官网链接:
http://www.atmel.com/tools/ATPOWERDEBUGGER.aspx
 楼主| 发表于 2015-12-20 18:48:17 | 显示全部楼层
官方售价:162.94美金,洗洗睡吧~
GMT+8, 2025-10-29 21:01 , Processed in 0.162750 second(s), 5 queries , Gzip On, Redis On.
