admin
发表于: 2015-4-22 22:24:06 | 显示全部楼层
官网介绍:http://www.atmel.com/zh/cn/tools/ATSAMV71-XULT.aspx
The Atmel® | SMART™ SAM V71 Xplained Ultra evaluation kit is ideal for evaluating and prototyping with the Atmel SAM V71, SAM V70, SAM S70 and SAM E70 ARM® Cortex®-M7 based microcontrollers.
Atmel SMART™ SAM V71 Xplained评估套件是一款评估Atmel ARM Cortex®-M7系列SAM V71, SAM V70, SAM S70和SAM E70系列控制器的理想平台。
Extension boards to the SAM V71 Xplained Ultra can be purchased individually.
Key Features
  • ATSAMV71Q21 microcontroller
  • One mechanical reset button
  • One power switch button
  • Two mechanical user pushbuttons
  • Two yellow user LEDs
  • Supercap backup
  • 12.0 MHz crystal
  • 32.768 kHz crystal
  • 2 MB SDRAM
  • 2 MB QSPI Flash
  • IEEE 802.3az 10Base-T/100Base-TX Ethernet RMII PHY
  • AT24MAC402 256KByte EEPROM with EUI-48 address
  • Stereo audio codec
  • External PLL for precise clock generation
  • Microphone jack
  • Headphone jack
  • ATA6561 CAN Transceiver
  • SD Card connector with SDIO support
  • Camera interface connector
  • MediaLB connector
  • Two Xplained Pro extension headers One Xplained Pro LCD header
  • Coresight 20 connector for 4-bit ETM
  • Arduino due compatible shield connectors
  • External debugger connector
  • USB interface, device and host mode
  • Embedded Debugger
  • Auto-ID for board identification in Atmel Studio
  • One yellow status LED
  • One green board power LED
  • Symbolic debug of complex data types including scope information
  • Programming and debugging
  • Data Gateway Interface: SPI, I²C, 4 GPIOs
  • Virtual COM port (CDC)
  • External power input (5-14V)
  • USB powered
  • Supported with application examples in Atmel Software Framework
GMT+8, 2024-11-7 21:37 , Processed in 0.058987 second(s), 6 queries , Gzip On, MemCache On. Powered by Discuz! X3.5
